IRONSIGHT (English Support)
If you find any possible bugs, please report 'em here and we'll fix them immediately.
Feedback is always welcome too :slightly-smiling-face:
IRONSIGHT is a light theme for Invision Community 4.5 with basic white / grey colors and a nice layout. It's free and comes without any brandings or visible copyrights.
You can see a LIVE DEMO on our site at InvisionFocus.de (select Ironsight in the footer). Tested with Forums, Pages and Downloads.
This is no multipurpose themeframework and comes - believe it or not - without any additional template changes, only custom CSS and build in IPS 4.5 theme settings.
Although it's not equipped with millions of additional AdminCP settings, it is customizable in many ways. As far as possible the default settings are used and for advanced customization we have a support thread in english language too.
This work is fan art inspired by Project: Ironsight, a next-gen military first person shooter by WipleGames, which is free too and availiable on Steam.
  • V0RT3X änderte den Titel in IRONSIGHT (English Support)
  • 10 Monate später...
@V0RT3X
Have one question - have you some code for sticky sidebar for Ironsight?
If i use your plugin - should maybe destroy my another skins what have sticky sidebar?
regards and thanks
Your code above should i put in ironsight.css or custom.css? I put it in ironsight.css and works fine?
Bearbeitet von Bosss
vor 22 Minuten schrieb Bosss:
I can take a look tomorrow afternoon.
Simply use ironsight.css, will be implemented in next update anyway.
Thanks for reply - tested your plugin - sticky sidebar - (on my test site)  works fine on default skins and your Ironsign but destroy another skins! Should be fine if we vcan choose skin to use with plugin! But never say never!
regards
vor 6 Stunden schrieb Bosss:
@V0RT3X Take a look in picture  - reactions icon is invisible
That's because we use a very light thumb-up image on this site and happens in the unmodified default theme too.
Can be fixed with a little bit of custom CSS, look here ...
.ipsReact_button {
  background-color: #2988CD;
  filter: none;
I can look at the spacing tomorrow, very busy today.
.ipsReact_button {
  filter: none;
Thanks
Spacing i fix with this code
.ipsBox {
  margin-bottom: 20px !important;
but do not know if is it correct ?
