add custom font to admincp
Arash.Ranjbar
OK, back at the PC and time to write something more. If you really want to code your own plugin you should check out the Developer Documentation, starting with this tutorial.
And don't forget the Help Guides, there's a lot of useful stuff hidden too, like articles about the template syntax or the CSS and JS framework.
Also VERY importrant is the forum and the search function. I'm sure all of your questions as a beginner are already answered there. You only have to search, read and simply try.
Learning by doing is the best way of learning :winking-face:
