recent topics for ips 4.6.12.1?
Mazzoni
ps: I have this one that I found on a brazilian ips forum, they say it works on 4.6 but i'm not sure...
It gives me an error XD
If anyone could take a look if it really works on 4.6.... :grinning-squinting-face:
Edit> The error it gives me is this:
[[Template forums/front/index/index is throwing an error. This theme may be out of date. Run the support tool in the AdminCP to restore the default theme.]]
I have tried going to Template > forums/front/index/index reverting it back, even cleared my forum cache but nothing works...
Found the logs here... What should I do? XD
#0 /home/domains/trollei-animation.com.br/public_html/forum/system/Db/Db.php(659): mysqli_stmt->execute()
#1 /home/domains/trollei-animation.com.br/public_html/forum/system/Db/Db.php(938): IPS\_Db->preparedQuery()
#2 /home/domains/trollei-animation.com.br/public_html/forum/applications/recenttopics/sources/Member/Member.php(105): IPS\_Db->insert()
#3 /home/domains/trollei-animation.com.br/public_html/forum/applications/recenttopics/sources/Member/Member.php(73): IPS\recenttopics\_Member->save()
#4 /home/domains/trollei-animation.com.br/public_html/forum/applications/recenttopics/sources/Member/Member.php(55): IPS\recenttopics\_Member::load()
#5 /home/domains/trollei-animation.com.br/public_html/forum/system/Theme/Theme.php(880) : eval()'d code(1805): IPS\recenttopics\_Member::loggedIn()
#6 /home/domains/trollei-animation.com.br/public_html/forum/system/Theme/SandboxedTemplate.php(61): IPS\Theme\class_forums_front_index->index()
#7 /home/domains/trollei-animation.com.br/public_html/forum/applications/forums/modules/front/forums/index.php(216): IPS\Theme\_SandboxedTemplate->__call()
#8 /home/domains/trollei-animation.com.br/public_html/forum/system/Dispatcher/Controller.php(101): IPS\forums\modules\front\forums\_index->manage()
#9 /home/domains/trollei-animation.com.br/public_html/forum/applications/forums/modules/front/forums/index.php(52): IPS\Dispatcher\_Controller->execute()
#10 /home/udomains/trollei-animation.com.br/public_html/forum/system/Dispatcher/Dispatcher.php(153): IPS\forums\modules\front\forums\_index->execute()
#11 /home/domains/trollei-animation.com.br/public_html/forum/index.php(13): IPS\_Dispatcher->run()
#12 {main}
Bearbeitet von Mazzoni
